Oil
grooter
upstate newyork
Ive Got A 2000 Phazer Which Runs Amsoil And My Viper Is Running Yamalube Synthetic. Whats The Best Oil To Run In Both Of These?? The Phazer Seems To Run A Little Rich. I Have To Change The Plugs Often. Whats Your Suggestion????
For a power valved motor like you got in the viper you should run the amsoil
interceptor,on the PZ you could lean up the pump some and use
the same oil in both,,or yamalube in the PZ ....$.02
and yamalube is only a semi-synthetic,amsoil is full syn.
I Think Ill Go With The Amsoil, Pz Is Already There But I Am Going To Adjust The Pump A Tad! Thanks For Your Help
Any oil is good oil.
I used to be religious about it too, but if your machine is in ok and basically stock condition, pretty much any will do.
40,000 kms on 3 sleds with Castol dino blend cheap walmart stuff. No oil failures, power valves get crusty about the same as yamaha stuff.
Corey
