2003VIPERER
I AM INSTALLING A CLUTCH KIT IN MY 2003 VIPER AND I WAS WONDERING IF I HAVE TO CHANGE THE ROLLERS TO A BIGGER SIZE. I HAVE STOCK ROLLERS IN IT NOW. ANY HELP WOULD BE GREATLY APPRECIATED.
2003VIPERER
Was Told Stock Ones Will Work
What clutch kit?
What clutch kit are you installing? If it is Heel Clickers they don't work very well with those stock 14.5mm rollers. To my knowledge (as limited as it might be) most other clutch kits are OK w/ the 14.5's.
Madmatt
Madmatt
2003VIPERER
It Is The Old Style Heel Clickers. Turk Said The Stock Rollers Would Work Just Fine.
i switched from stock to 15 s and thought it was better
The problem youll have with 14.5mm rollers is the sled will explode with power out of the hole and will be about impossible to hook up, no matter how many or how the stud pattern is. Not to mention with 14.5mm rollers you need to be extra carefull as the heel with weight added to it can touch the moveable sheave and when this happens and you suddenly decellarate the clutch goes boom and peices of weight and belt will fly eveywhere, its alot safer to use at least 15-15.6mm rollers and the shift curve and all will be better in the end result. I have used 14.5 rollers before with success but you have to be extra carefull and have a good working knowledge of h/c's, your weight amount and all will be significantly differnt and its alot easier for a novice tuner to start with 15-15.6mm rollers.
2003VIPERER
Thanks Mr.viper. Will Have To Order Them From The Local Dealer. I Need To Get The Rollers From The Srx Right?
Mtnviper
15mm = 8CR-17624-10
15.6mm = 8CR-17624-20
Don
How well do H/C 40/10s work with 16mm rollers for drag racing?
Don
2003VIPERER
Thanks Mtnviper. I Am Ordering The 15mm Rollers Today. I Will Keep You Posted On My Clutching Progress.
