Airbox carb vent?
Rochester, NY
im taking off a tempaflow on my viper and dont remember exactly how the the carbs vent into the airbox?
does the nipple on the 3way-fitting that the vent lines plug into just insert into the hole in the airbox?
i currently have a hose on the fitting that goes into the airbox, but i think that is just for the TF.(?)
thanks
do i still need the vent line that goes into the airbox?
the vent line comes off the nipple and goes to the TF, do i eliminate the vent line?
thanks
you just hook the vent from the carbs to the rubber deal in the air box. If the rubber is gone, feed the hose in, and put the t on the inside to hold it tight. Maxdlx
