zooman
I have taken the sled out for a few rides this week and a couple of times this week it has fouled the fan side plug. I have put new plugs both times and it did the same thing. I have taken the carbs off and given them a good cleaning before I tried to ride the machine.
The sled also has stalled on my a few times. I will be riding to a stop sign and sometimes it will just stall or it will bog and if I flip the choke half on it will rev out again and I kick the choke off and away I go again.
Any ideas guys?
Matt
Any ideas guys?
Matt
air jet is plugged
silversnow
Check the choke plunger adjustment. That's what my phazer did when i had the the choke on to much. it would stall at a quick stop. and foul plugs and run on one cyl.
Silver
Silver
zooman
Ok so I will clean the carbs again to make sure no jets are pluged but first I will try to readjust my choke plunge.
When I adjusted my chock it seems that I have to back the adjuster along way out to get the free play I am sopposed to have. Am I better off having the choke adjuster screwed a litle tighter to be better safe than sorry?
I am pretty new at this sled,
Matt
Matt
silversnow
Well the cable free play spec is .5- 1.0 mm. As long as it is within that you are good. But if you have more then that it could make if hard to start. yes better safe then sorry.
silver
silver
zooman
Problem fixed
Hey guys thanks for the help. I decieded to take my sled to get looked at and the shop cleaned the carbs and now the sled runs excellent.
It was the low speed jet on the right side was pluged. I guess when I used carb cleaner it wasn't enough. But now the sled runs excellent.
I just wanted to pass the info on.
Appreciate the help fella's.
Matt
Matt
