Anybody make a front end widening kit for a 2002 viper
Bearit
yellowknife,northwest territories canada
Hi guys
I just added my boss highrise and also have a m10 rear suspension on my(non mountain 2002 viper) so I want to know if anybody sells a aftermarket front end widening kit for the front end to make it more stable in the corners.
Steve
You might be better off with one of there sway bar kits. The medium one really makes the front end work better. Maxdlx
we built a wide front end for a friends sled last year and it rode great, handled great and sucked when putting on the trailer.
by the end of the month i should have a front end widening kits back from machinist ready to sell.
you do not need a stiffer sway bar with wider front end. sled will set lower though.
Very interested in this kit,please keep me informed as to when you can show pics and tell me the cost.
Steve
you can have any place that makes radius rods do it for you I just went back stock length & had them use inch threads on the outers to save money on the rod ends i just drilled out the trailing arm holes w/ a 1/2". I used 1/2" ss allen heads but have switched to SS
1/2 hitch pins with SS pins.
