variflow install on filters?
yes you vent it to the atmosphere. I take it your vent lines are now to the atmosphere? Maxdlx
yeah they are right now, installed filters and still pig rich. got races tomorrow and dont have the time to find all the jets and do the needed changes. max how do i hook everything up? ive been searching this for over an hour on different sites and cant find any info
Thanks max everything is clear now. i will hook it up in the morning and try it before the races.
once again Thanks i really appreciate the help.
i took third but have the ability to win, the belt was really tight and every time i would let go of the gas the sled would keep going. at the line i would have to hold the brake and try to let it go while hitting the gas in 4/10th of a second and then the sled woulg bog off the line. i got the cen-cen and the offset perfect now so it should be good. also with the 180psi of compression and the vents to atmosphere the sled was pig fat but leaned it out with the variflow. ill keep you updated on my progress.
