vdo on srx
its in the hood harness, undo the tape and youll see it plain as day
can any one help would really like to make some passes on the sled to see how it runs with the big bore and spray.any help would be great
on the dip switchs on the back 1,2,3 should be on and 4 off
(blue wire)-not used
(green wire) - goes to the yellow with blk stripe on srx harness, this is the tach feed wire
(white wire)-unused(light)
(black wire)-must be grounded to chassi and if you run a battery ground it to the neg post as well.
(red wire)-12volt power source wire from battery
(yellow wire)-unused
