Question for Vipers w/ 8dn20's
Fardoche
Canada
What kind of rivets are you running with your srx weights?
I have a 2002 Viper, stock engine and gearing, has engine tensioner, 1.25 camoplast, stock secondary, 8ek's loaded w/ max rivets in both holes, stock rollers.
I still have an overrev with the 1.25 track, so got me a set of 8dn20's w/ the rivets in, wondering if it will be a bit too much to pull?
i would ask Turk but personally i run a 53/43 helix and green spring in the secondary...... 8ek's with 4.5 in both...love it
friend of mine went to the 8dn20's cause they were cheaper but not sure which rivets although i believe its 4.5 in both....that set up works very well also....
:letitsnow :letitsnow
so your running ruffly 48 grams of weight in your viper..and he'd be running ruffly 50 grams or so..you dont think thats to much for a single pipe viper?
ur right that is a little heavy, i just confirmed with my friend and he runs the stock 8dn-20's with 4.5(17.2mm) outer,3.6(13.9mm) inner which makes a little more sense.
