what's your helix windup for , anyone running 60 degrees on Red?
Rambunctious
Holland, Michigan
I have clutching done on my 2000 srx
4.5 gram rivits in both holes , stock weights, www primary,
and stock red secondary
I started with 80, and great accelleration but lsot some top end acelleration
was hitting 8900 rpm - too high obviously
put it to 70 and dropped rpm to 8600
is anyone running 60 degrees?
how do you know if it is too little windup, does the clutches slip?
I set it to 60 but did not have time to do a final test, heading on a weekend trip this weekend and want it correct out of the box.
and how warm is too warm for a secondary, warm to the touch ok?
Ramb
