viperino
How often do you guys change the clutch springs? They generally always look ok but should they be replaced every year or so due to fatigue in the spring?
Unless the spring is broken or your losing rpm,s (spring is sacked) don,t bother. Yammie uses softer primary springs & they tend to last a long time.
viperino
thanx..... again
