Rambunctious
anyone running as low as 60deg windup on secondary -
on red spring?
I have another thread asking this but typo in the title made me look like an idiot
ramb
on red spring?
ramb
yamaholic22
In conditions with very low load you can run a red at 60 but if you get real good traction in most situations you will probably find that running it that loose causes an overshift and/or belt slippage in the secondary. Typically the red is run at 70 or 80 degress twist.
Rambunctious
thanks
I am at 8600 on my 2000 srx. with 70deg. I was looking to drop 100 rpm by secondary twist. I have the 4.5g rivits in the primary already.
but I may keep it at 70
are there heavier rivits?
will the green at 70 show higher rpm or lower
thanks
Ramb
thanks
Ramb
