Enticer...almost done
sifton
Manitoba, Canada
1980 Enticer. Waiting for a few parts.
82 Enticer
Hi im working on a enticer 340 it had been sitting clean carb/fuel tank went to start no spark supposely it had spark says the owner when he aquired it 2 yrs ago and it has sat in his yard for this time uncovered he tried to start it by putting fuel in each cylander and says it fired at this time im just wondering if you know the proper way to test the stator on this machine ive done it on others i just want to make sure im doing it right it seems that i have nothing coming from the stator i tested the brown wire to ground and the yellow wire to ground nothing my first thought was could the flywheel and pulse coil pickup just rusty ive gone thru and checked the ignition switch wich was bad so i deleted it then cheched tether switch/kill switch sorry if im bothering you just sounds like you probally know these machine pretty well thanks for any help scott
