viper spark plugs
Concept Carbon
Ottawa, ON.
what are you guys running for plugs, cyrrently im runnuing the br9es is there a better alternative with out switchin gto premium
ya i was thinking of switching to those i know you run them but, would it be ok with regular gas what about the eix (i think thats what there called)
Dont waste your money esp. on a stock machine. I'm gunna be running BR9ECS which are SRX plugs, just for the simple fact that they disspate heat better and I'm running pipes. My dealer told me that BR9EV are no longer avaliable unless you find leftovers, I use to run them in my bike.
s.s.viper
Tried the splitfire plugs several years ago when they hit the market. Thought they were great plugs, seemed to really make the exciter pull, but started having some kind of problems, thought it was the cdi.......determined it was the plugs. Change back to NGK and problem went away.
Got to talking to yami mechanic and he had found out that the fact that the splitfire doesn't have any narolling (sp) on the porcline (sp) that it was allowing moisture to get in under the plug wire cap.
Just some info.
the br9ecs is supposed to be anti fouling. do a search on this, there was a big discussion about this last year.
has anyone run the iridium BR9eix plugs, Im not worried about fouling the br9es just wondering if i would notice an improvement in starting and snappyness if that makes any sense.
If i run an iridium plug do i have to switch to premium fuel.
I've been running Iridium's in my 01 mm 700 and my piped 03 viper for two years now have fouled one before the mm used two foul regular br9es every second ride. SHANE
