Viper engine problem, must read
Stevie Ray
Minnesota
Thank you everyone for your help but I have just found my nasty little problem. Here is the whole story so you can save this one on your hard drive for future reference. ---- I was out for a ride with some buddy's last saturday we had just shot off the lake to hit the trails. The snow conditions were not that bad (about 6 inches or so). I got down the trail about 4 miles (estimated speed 40-50 mph) then the machine stopped dead. I proceeded to pull the plugs and they were nice and toasty brown. Then I grabbed the clutch to turn it over. It was a little stiff so I added some oil to the cylinders and kept turning. It seemed to free it up. I got the engine started to limp back to the trailer and it died again. When I got it home I pulled the cylinders and everything was perfect. As I would spin the engine over it would turn fine and then tighten until I would turn very hard then it would free up again. Well time to split the crankcase and there it was!!! The bearing between 1 and 2 connecting rods. I just checked on the price of the bearing and it looks like its 47 bucks. I wonder how much the labor will be to install it. Well there it is, the first time any Yamaha I have ever had, has had bearing failure. Anyone know why the engine would kill because of this bad bearing?????Maybe my Viper will be traded next year. Vector?????? :o|
the details
This sled has a little over 3000 miles. I bought it used so I dont know if the speed o can be unhooked or not on these Vipers. When I bought the sled I did spot heavy rust on bolt heads, exhaust and even on the flywheel. I figured it was in a moist storage area with a dirt floor. I ran the sled last year for 700 miles without any trouble. One thing I did do this summer was starting it every month and a half. I was checking to see if the carbs would still gum up as bad as not starting it for so long. Well the carbs looked a lot cleaner inside but maybe it did more harm than good. I only ran the sled for a minute each time. Maybe that just adds moisture to the crankcase?????
Ive heard starting it for just a minute or so is bad, exactly like you said. It doesnt have time to warm up properly and evaporate the moisture. When I start mine I run it at least 10 to 15 minutes, dont know if thats enough either, but thats wat I do.
Good luck with the rebuild!
