my buddy wants to stud his 2003 viper what size studs what pattern and any thing else that needs to be done Thank you
richierich
depends on brand stud but 1.075" to 1.25".all he needs is studs and backers.let me know.thanks
don't have to add heat exchanger protectors
richierich
that sled has them already.
Concept Carbon
I wouldnt go past 1.175 i just ran 144 down the middle and the 1.175 are very close to hitting I would stick with a 1.075. A v pattern works well and is easy to do.
Stevie Ray
I was wondering what track you are running??? I run the 1.250 Ripsaw on my Viper with studs and haven't had problems yet. Maybe I better not jump anything???????????????
Concept Carbon
if you have protecters you cant run anything bigger then a 1" i have the 1" preditor with 144 1.175 and i can see scratch marks where they have just touched my tunnel
Stevie Ray
If you are talking about the aluminum protectors on the front exchanger mine were removed by a dealer to put this track on. They just ripped them off...
Concept Carbon
wow your playing with fire then, i would not be running that track unless you get 8 tooth drivers.
Stevie Ray
Have you ever danced with the devil in the pale moon light??? Just kidding! I might have to do some reconfiguration. Thanks
Concept Carbon
lol, tip you r sled over and check the fron exchanger, also make sure to keep your track snug.
akrievins
Do 1.075" studs offer enough traction on a stock 03 Viper track?
All I want to do is put 144 down the middle with no additional protectors or anything. Simple install. V pattern. Looks great and was easy on my PZ II (96 studs).
richierich
yes they will give you 1/4" past.
Concept Carbon
yep more then anough i thought it was more like 3/8 past on the stock track and a 1/4 with a 1" camo.
woolyviper
1.175 on the stock track is the ragged edge. If you need a pic let me know.
richierich
02 vipers had .92" tracks and 03 had 1" thats where the differance is.on a 02 i wouldnt use anything bigger then the 1.075".
