m-10 with offset axle adjustments
01&02SRX
Grafton Mass
I just installed an m-10 with a Performance Engineering offset axle running Fabcraft 8" rear wheels on the track tension I have a couple of questions. 1) It has a new track also it seems a touch snug is it ok because it is going top stretch correct? 2) on the fabcraft axle to tension the track do I every time have to take of the rear wheels on the outside to get to the locking bolts that hold the axle in and clamped on the side rails of the m-10 or are those bolts supposed to be left somewhat loose so the track tensioning bolts can do their thing seems to be a pain to get to these bolts everytime you nedd to adjust the track!!!! ANY HELP WILL BE GREATLY APPRECIATED tHANKS STAN :letitsnow
no not without taking off the outer rear wheels u need to ether take them off and try to get them back on with the track tight or leave the lock bolts slightly loose!
