hyvo gears???
Concept Carbon
Ottawa, ON.
ok im looking into gearing down my viper, maybe to a 20 or 21 top and a 39 or 40 bottom. Im thinkin of gettting my gears from royal distributing are these hyvo gears will they work with my stock chain. royal gears
also what do you guys recomend for good low to mid 0 to 80mph, most of my riding is in the trails, im new to gearing and curently run stock except for 53/43 green spring.
20-38
20-39
20-40
21-38
21-39
21-40
yep thats what i was thinking, sense i have a bit of over rev i seem to be reving at 9000 when moving if i pin it. my belt is riding a little bit low though
alot of the vipers from the factory overreved to 9000 which loses mega top end.Gear down to a 21 and put a set of heel clirckers in there it will be like a whole different sled and will pull hard.
yeah it feels flat around 160kms hopefully the gear will help. I was thinkin gof gettin gthe heel clickers but then i will have to get a new helix. i will try the gear and go from there thanks for the help
