jclee71
Any suggestions on a rear suspension set up for a srx 600.I havent made any adjustments to it since i bought it two years ago but feel I need to. I dont feel im getting any weight tranfer. Sled runs strong but doesn't lift the skis and seems to dart pretty bad. I weight 230 lbs, studded, with bender adjustable transfer rods. Is this typical of the SRX or is my suspension set up all wrong? My buddies 95 vmax 600 with an old unstudded track gives me a good run because a cant hookup out of the hole.
Concept Carbon
I would adjust front shoks to 1/2 midle shock almost max and rear shock only 1/4 to 1/3 and loosen your limiter straps out. if that dosnt work you can drill new wholes for your transfer rods.
dont drill holes for your transfer rods, only work on 00-02 models srx..
but the rest is right on!! if you want more power in the holeshot, gear it down a bit.. i when i had the 600 (21-40) and it made a world of difference!
bluewho
If your sled has just started to dart badly the front skid shock needs rebuilt or replaced!It will not help hold the sled up putting no pressure on the track and to much pressure on the skis.
RIVERRUNNER
Powerpack were you clutched when you were running 21-40 in your srx6?
