Viper Sniper
does anyone here know if Viper Radius rods are the same length as the 2000 SXR radius rods? Which other sleds can I get rods from to replace on the SXR???
viper upper rode is different in a few ways that make it not work. lower is similar and will work.
all rods from ventures, xt, xtc, sxr are the same lengh
Viper Bush
Back from the dead...
Are the viper vs srx rods the same length though? I have an 02 Viper and found a set of uppers and lowers from an SRX and I'm wondering if these will work. Same length? I've heard of issues going Viper rods into an SRX due to the width of the bar on the lower of the Viper being too wide, but would it work putting SRX rods onto a Viper?
Will they work?
Will they work?
Viper Bush
I've found the lower rad rod is 7/8 inches thick. The upper is a thinner 3/4 inches thick. The lower rod measures about 17 1/4 inches long (not including the swivel joint on the end). I wasnt able to get a good measurement on the upper because I don't have it out yet, but the upper seems to be longer. Is this correct? Or is the upper the same length as the lower, only not as thick? Does anybody have a measurement of Viper vs SRX upper and lower radius rods, length and thickness??
Please help! I've searched and searched on this but all i find is conflicting information. The part numbers are different for the different models though. Or does anybody have a set of Viper rad rods lol?! All I can find are SRX rods....
