EGT Temps?
full tilt viper
Southern Ontario
What kind of temps are you guys running on your piped vipers? At idle after warm up i'm at 675- 695, 7000 rpm 1125-1160, 8500-8800, 1240-1275 wash is hard to tell ( brand new pistons ) but the plugs look good. The mid range looks a little high. Any opinions out there?
Steve
those numbers are all higher than mine, but that means $hit. Altitude, temp, and probe location will all change the numbers from sled to sled. I also have a mega power head. You need to runn it enough to check wash, then turn on the egt. Maxdlx
If the probes are 4-5" out then your close on temps, but usually they are out farther than that. Actually that looks a little low for probes out @ 7-8" from the skirt. 1350 is a good number for 7-8" out @ full throttle.
