Procedure for removing Tach in SRX
Howden ,Manitoba,Canada
I am sure I have to disconnect the headlight and carfully take out the whole headlight so I can get to the Tach.Don't want to break anything in the headlight area.
If you have small hands you can just simply undo the cables and use a wrench, i think 10mm and take the tach out, a little harder to put back in. If not just take the windy off and then disconnect all cables and wires and remove entire gauge pod, oh ya there is a small plastic screw that holds the pod to the headlight take that off too.........been there done that both ways.............James
