ducky_d
- May 21, 2003
If im going to pipe a 2003 Viper Mountain, Is it a big difference if i choose SLP:s or Hauck/Cimmons cpr pipes
Most power
Quietest
Can you do trail raiding and 3-4 minutes hillclimbing with wot
Do you get a very close window to clutch in
Any other inputs
Please help...
Most power
Quietest
Any other inputs
Please help...
They are both great pipes but I think SLP has a lot more experience at hi altitude tuning.
I have SLPs on mine. Yes they are louder than stock, but quieter than most other pipes, including SLP's mtn max pipes.
They work best at 8800-8900 rpms on my sled. The SLP jetting chart is very close. I'd start with their jetting specs first, then check your plugs, you might be able to go down one size, and maybe 1/2 position on the needle clip. The SLP jetting chart does skip some sizes ie; 152 to 150. You can buy the in between sizes from Yamaha, ie; 151.3s although they are more money.
They're clutching chart was off for me. Mine is a 02 Viper that I put a 136" track on, and ride the mountains. I found that the pipes just didn't like the 8Ek weights at higher elevations (4000'-7000'), they work fine down low. It would under-rev on the bottom end and over-rev on the top. I switched to 8CRs and instantly got a straight shift. Your Mtn Viper I believe comes with 8DN-10s. They have a force curve that is similiar to 8CRs and should work fine.
I do a wide range of riding, trail, boondocking, climbing and drag racing. The SLPs are working well for me, fuel mileage is pretty good as long as you dont ride all day long with it pinned to the bar!
ducky_d
- May 21, 2003
Are you happy with the new power you got ?
Is it worth the money ?
Very happy with the power! I got mine used, they're ceramic coated so I was able to save a fair amount of money. I'd check the web site swap meets, sometimes when guys are trade/selling thier sled, they will pull the pipes and sell them.
