littlebear
Hey all. I am successfully running a 98 srx motor in my 02 viper. The viper motor blew up three times on me and I got frustrated and put a 98 srx motor in it. It hasn't had any problems with melting down or pistons since I did it. Seems to be a more reliable engine. Just lettiiing you know in case anyone is doing it and needs help or advice.
clint
clint
bluewho
Good to know stock srx pipes or?
snow3
I also did that swap, which wiring harness did you use?
BETHEVIPER
Life Member
there was a guy on here once that did it, not sure who it was. reallly good looking guy though. had big hands and big feet too, you know what that means?????
big gloves and big shoes
scrapy
- Dec 27, 2005
viper problems??
were you having alot of problems with your viper the reason you switched this out or what?? I've rode mine for 4000 miles and no problems.
snow3
No problems with the viper motor.. I just wanted to have a fast, reliable viper with tripple pipes that got good fuel mileage.. I also like to suprise people when the viper gets to the other end of the lake first, that did not always happen with the stocker...
BETHEVIPER
Life Member
4000 miles, lets say they are all good days, you bought 400gallons of gas, a srx piped viper gets 15 on its good days, it used 140gallons less than you, at 2.40 per gallon that is 336$ more that your pipes cost and counting while you spin the rullet wheel at 9000rpms. not to mention that that same sled will use more oil in that time. you also made 14 more trips to the gas station.
all this is assuming you got 10mpg which is being generous. ive heard of some 12mpg vipers out there, one in town i sold a cylinder to. real safe.
also there is range, some riding requires a safe 100-120mls, piped vipers are close on these trips.
other reason i found had to do with iconsitant jetting, stock shielded pipes keep the air box temps closer to outside temps and they also keep the pipes hot. both these things make jetting way more consitant witch in turn makes the sled run more consistant.
mrviper700
VIP Lifetime Member
Hey Scott, in post number #4 on here, I am glad you brought that sled down to me to put the engine in for you....LMAO!!!
littlebear
Hey snow3. I'm using the viper pipes by aeen. And I used the Viper wiring. I had to swap the bottom crankcases so that I could use the viper flywheel because the pickup has different positioning with the new smaller flywheel. Also I wanted the 300 watt light system.
Bearit
Hi there
Could you please add pics of this setup as I am cosidering the same thing,and what mods did you have to do.
Thanks Steve
Thanks Steve
wilsviper
Did you have to do any butchering to get the pipes in?
yamaholic22
wilsviper said:Did you have to do any butchering to get the pipes in?
Yea you have to cut some out of the shock tower on the belly pan and you need to modify a silencer to fit it all and get it to line up.
