Prone to fouling
EricMichael
Presque Isle, ME
I noticed the mag side cylinder runs alot richer than the other two, middle richer than pto(clutch sde) . Would it be safe to turn the fuel screws back on the other two slightly for leaning it out alittle more or just deal with changing a plug once in awhile, i'd rather not blow it up. i've put 3,000 miles on with stock head/gasket with pipes and been safe so far.
I put one pair of plugs in a season. Never had a problem fouling out plugs or bad gas miliage. Check and reset to stock if need.
shortstop20 said:
Fuel screws only affect fuel mixture from idle to 1/4 throttle, so that won't solve your problem. You may have to drop one main jet size.
yeah I was thinkin that may be the problem, i'll try and see, thanks guys!! :letitsnow
