sockeyerun
Test Dummy
Will the newer style mountain skis (05'- newer Viper mtn.) fit on a 2002 mountain max ? Thanks Soc
gild
yes
yes 07 Apex mountain skiis fit my 01 SXr bolted right up!
yamaholic22
yea dude, bolt em up
sockeyerun
Test Dummy
Thanks guys,Soc
TJ500
just recieved a set of mountain skis too but they look as though I might loose some ride height once installed... Is anyone shimming the skis or using shock adjustment brackets to gain a little ride height?.. 2002MM700.. thanks
I actually gained a little over the Simmons. Way deeper keel.
you have to get the mounting kit with the ski's the bushing is longer and comes with 2 spacers for spacing the ski how ever you want it.
..SNAKEBIT..
I think he is talking about height
I beleive on the older sleds you need to adjust the spring to regain ride height
and as Ryan said the installation kit has bolt and bushings to adjust width of stance
GREAT mod I did mine last year bought everything from Kevin
