Handguards
akrievins
Mississauga
I'm looking at buying the Star Series PowerMadd handguards for my Viper.
Does anything have to be moved/removed to mount these, or is it a simple install?
If you havent already, run a search on the subject. There have been many posts on this subject along with discussion on bar risers. Most of these posts have many pictures which should give you a good idea on what things look like.
That being said, If you use the Powermadd hand guard mounts, and want to use your parking brake, you will have to move your brake lever and switch block inward (toward the center) on the bar so the mount can be placed between the grip and brake block. In order to move the brake block inward you will need to remove a welded anti-rotation tab off of the handle bar. You can remove this tab pretty easliy by bending the tab back and forth with pliers then filing the rest of the weld off.
I believe that if you use the Rox mounts you can place them on the inside of the brake block which would be ideal. I didnt go with the Rox mounts because I was cheap.. Here is a picture of my Acerbis hand guards with the Powermadd mounts. G.B.
wow that sled was slick!
It hurts me to see these pics and it's not even mine!
Thanks for the post. I might go with that mounting set up.
Yeah..I think it was gone blue that helped me with my Brake dilema...I managed to move em over slightly and everything works trick...of course you can probably go the Rox route and save that slight frustration../My set up is Grip/Mount/Brake or throttle...
good luck...
