Screeching Belt
Lab_fox
Canada
Hey guys i own a 99 mm700 and the other day i blew a belt replaced it with a a yamaha spare i had and bought another yamaha belt as well. since blowing the belt. after riding the sled for a while and after stopping the belt screeches. doesnt do it on start up just after it has been moving for a while.tried both belts the both behave the same way. was told the clutch might need to be adjusted. if so is it somethin gi can do myself or should i bring it to the shop. any ideas/ advice is appreciated
very easy to do, remove the secondary clutch and on the back there is 3 bolts which may have washers you need to add/remove washers until the belt sits max 1.5mm or min. of 0.5mm above the secondary sheave. where are you from?
right on had to put my machine in the shop today think i busted the chain. well there is definately something wrong in the cahin case. hoping its only the chain and not something more serious
