My Speedo Fogged up
2datrl
NE IL.
Was riding the Northwoods of Wi. this past weekend, and my speedo had droplets of water on the inside of the "glass". This did not happen last year.
It's not like we were riding in the rain or anything. Daytime highs in the 20s, single digits at night. Any ideas?
Thanks, 2datrl
check the rubber boot on the back of the speedo where the cables go in. if it is askew the heat from the motor will get it to fog up. best to put it somewhere warm with the hood up and that boot off so it gets good and dry. hair dryer might do the same. then hook the boot ack on and try again. hopefully it will work for you! let us know
This seems to be a common prob. In fact Snowtech mag did a little write up on it a few years ago. There is a new boot that seals better. I bought one and lost it when i moved. When i find it i will send you the part #.
