shock question
mmax99
canada
Anyone out there know of an after market shock that will replace the front shocks on 2000 mountain max 700 without changing the ride height. or is OEM the only option. My factory shock let go I was considering getting it recharged but it was showing signs of an oil leak prior to total deflation
just look for a set of used or take-off shocks on the site, guaranteed you will find a couple sets that will work for you, and probably cheaper than even a new aftermarket set.
a friend has bought a set of works from harman for his mm7. they seem nice and arent too spendy. rebuildable too.
thanx man
looked into shocks looks good hartman's are cheaper than stock I had a friend order a stocker for me I'm going to look into cancelling order on shock and getting hartman's they around the same pice and hope they are superior to stockers if anything they would be diferent than all my buddies
perfect
I was able to cancel the order on the stock shocks talked to Tom Hartman today and he sending me aset of works for the front end the cost works out to the same price as to new stockers thanx for the input
