Offset axle question
langow
WI
Has anyone installed an offset axle into a stock 121" proaction suspension? I recently purchased one from HPE and after I got it, it looks like my transfer rods will be directly in the way of where the new track tension adjusters need to be mounted.
It seems like with any of the offset axle kits, I need to remove the bracket for the stock track tensioners. These are riveted into the rails, so I don't want to remove them only to find out I can't mount the new tensioners because the transfer rods are in the way.
Any ideas? Thanks.
