Clutch recommendation for 440 Exciter
poiboys
Looking for a recommendation for spring and cam arms for Comet 102C used in a 440 Excter oval racer. Sled has twin carbs, mild porting and stock pipe. Driver weighs 190 lbs. Tracks are usualliy about 1/3 mile long. Any suggestions?
Re: Weights
Hi, a friend whom I talk with on line has a late 70's or early 80's EX-340 that he races. He is using a 102C with Thunder Weights which are adjustable. He had suggested them to me as well.
http://www.thunderproducts.com/media-03.htm
Sorry I cannot help with the spring but I do hope this is of some help to you.
Jarrod
Hey Poi how high does your power band kick in i have the 1978 exciter with twin 38s , GPX pipes , and boyesen reeds , My powerband is kicking in at like 5000 rpm , any ideas ?
Like this sled is WAY to boggy off the line , it bogs for about 50 feet then realy kicks in , any ideas would be great, im thinking maybe the GPX pipes raised the power band up Any one else try GPX pipes on the EX ?
