sxr engine temp
SNOWRULES
Ottawa. Ontario, Canada
Running with psi tripples, a rear heat exchanger and using water wetter in the coolant. the machine runs at 140 degrees f , 150 if there not much snow and 130 if there's lots of powder. do these water temps seem right is this the range i want to be in? water temp sensor is from an autoparts store and is put in with a t fitting in the hose that comes off the head.
