Snojet Steve
I'm finally getting a GPX ready but there's one little thing that I need to sort out. Which cyl does the grey wire coil go to and which side does the orange one go to? All my other motors are points or use the double coil so there's nothing to go by there.
Thanks.
Thanks.
Brad_69
Sno-Jet Steve.
My 74 GPX runs good. The orange wire on mine is set on the PTO and the grey is on the Mag. Brad
Snojet Steve
Thanks Brad! Did you just get yours together? Looks like the cdi boxes have the wires on either side too. At first I thought they were all jumbled together. This old fart should be ready to run as soon as I get the carbs in sync. It's a 75' GPX with a 74' Sno-jet engine, 75' SST carbs (36mm with 360 mains), Comet 102-C weights+ red/yellow spring.
Brad_69
Snojet Steve
Not bad! I like those hoods. I'm going nuts here trying to figure out spark issues on another motor. It's been so long since I dealt with CDI units or Mikuni VM carbs for that matter.
Brad_69
Whats wrong. No fire? Brad
