dave72
Hi need a little info had the chain off the chain case and the back clutch off of the sled and i tried to turn the jackshaft by hand and couldn't put the clutch back on no problem more leverage i guess it should turn free right ???
Its a 2000 srx been having a problem with top end i thought that might have something to do with it any info would be a great help thanks
It sounds to me like you have a bad bearing or 2. In my mind it should turn free.
dave72
ya thats what I was thinking thanks for the reply
bluewho
If you are checking it open up the brake pads with a screwdriver and try.They make it hard to turn by hand.
dave72
Hi there bluewho I did that that's what got me looking
bluewho
Right you are!! i have a highmiler and have replaced the bearing behind the secondary clutch!It will ruin the jackshaft if it is the culprit.There should be some play there if that is what it is.The chaincase top bearing will go forever unlike the bottom.The stock roters are heavy and make it hard to turn as well.
woolyviper
change both bearings as long as you have the chain and the clutch off. take them off and go to a bearing house, it will cost you under $20.
