churbbles
Could some one please help me find rear slide springs for my Exciter? I need both left and right rear ones. The dealer here told he could get the left one but not the right one.Would the springs from a 88 Exciter fit. Thanks in advance for any help.
nightmanx1
Did they make an Exciter in 1998.
churbbles
So sorry I ment to say a 1989 Exciter.
Brad_69
Ok, The part #s are different between the 88 and 89, but they look identical. You may want to try an aftermarket Co. to see if you have better luck. You may want to try Central Snowmobile at 1-800-558-6778, or Als Snowmobile at 1-802-487-1000. Hope that helps. Brad
nightmanx1
churbbles
Thanks nightman. I went there and there isn`t a listing for the rear springs for a 89. I can find front ones. This is the problem I`m having. I also went to Als & central. The yamaha parts cat.has a listing for one but not the other. I sure would hate to junk my Exciter for the sake of rear springs.Hope some one can help me out.
Brad_69
Give those two places a call and talk to them. Don't just look those parts up. I think they would be better able to help you. Brad
nightmanx1
one more place would be to call Central Snowmobile in Green Bay 800-558-6778
920-499-6001
920-499-6001
RelicRuss
Hey
If you couldn't find new ones you could always get good used ones from a wrecker. or try www.recreationsupply.ca for a set of new aftermarket ones.
Thanks,
Russ
Thanks,
Russ
churbbles
Thanks guys: I ordered a set from royal. Thanks again.
