wiring problems viper to srx
scrapy
I put a 02 viper motor in a 99 srx chassis, viper wrecked, srx no motor. Problem is I can't figure out which wires to tie together from viper wiring harness to srx gauges. I used all viper ignition,cdi and wires. Using srx gauges and don't know if since the viper had digital gauge and srx is mechanical if they will intermatch??? any suggestions or someone know which wires to make the low oil light and fuel gauge work????
i did this but i put the viper gauge on my sled looked trick.you just got to get a bracket made for the gauge.
