weaner
Hi ,
I dont know if it's a problem but , when my engine is cold , the headlight start after 1 min.
when the engine is hot , no problem ......
It's normal ?
or I gone to have some trouble....
THX
It's normal ?
THX
Skidooslayer687
What year is your sled??
weaner
srx 2001
The 00 and up SRX's will have a "slight" delay after you fire them up but certainly not a minute.
Skidooslayer687
mine did the same thing, i took the load control relay and headlight relay off and took them inside, put them on a heater and dried them out. Put them back on havn't had the problem since. Mrviper700 had told me about this problem. Sounds like the same thing is happening to you. The relays are located above the left footwell on the machine. Pull them off, dry them out and see what happens
