clutch adjustment
polarman
NY
Can anyone suggest the best adjustment for the secondary clutch on a 99 Vmax? It was sluggish on the low end so I replaced the spring and glides. Which slots should I use for the spring? Number 1, 2 or 3? And which hole on the outside assembly? The are number 0 thru 9..
start at 60* u take the first number and ad it to the second. so inside would be 3 and outside would be 3 and would ad to 6 then tienms 10 would be 60. or 1 and 6. i cant remeber the numbers on the helix but its simple once u knwo thast its one nuber plus the otehr times 10. and remeber twist clock wise. the higher the angle the better low end ull ahve(longer itll stay in "low gear")
Tried #2 and 60...seems better on the very low end but bogs a bit after the track spins...should I change the inner or outer slot? thanks
