Can't hold rpm past idle
Kris MM700
Greenland
Website
www.pbase.com
It's a stock 03 viper that we've just bought last autumn, only riden it a couple of times due to the lack of snow and at first it sounded like that it only ran on two cylinders.
But last time I ran it, after changing the spark plugs, it would warm up nice and sound like it ran on all three cylinders, but after around 5 min of riding, it would start bogging when giving it gas and die out when letting off the throttle.
Start it up again and it runs okay if I give i half choke for 10-15 seconds, but if I hammer the throttle it bogs and dies again. Have to give it throttle slow and steady to get it to rev and then I can ride it for maybe 20-30 feet and it'll start all over again with the same problem, die out if I hold the throttle or let it go and give it half choke.
I'm not sure when the carbs last have been cleaned, but I would have tried that out first, if I had a shop to do it in.
Any ideas?
dirty pilots most likely. clean em up if still the same try turning fuel screws out 1/4 turn at a time. i had to turn my screws out 1/2 turn after going to a 51/43 helix. had the same symptoms as you describe. if flipping the choke to half helps it means your not getting enough gas
Pat
