Checking needle settings?
1
2
3
4
5
Ok when you pull your needles there should be 2 nylons either on the clip or stuck inside of the slide. The e clip should be in the 3rd slot with both washer underneath(clip position 3) if your STOCK Viper hasnt been toyed with. But say you have the e clip still in the 3rd slot and you put one of the washers on top and keep one on the bottom, this makes your clip positon 2.5. By doing that it drops your needle farther into the main leaning your fuel intake. People have asked "what if" you put both washers on top would that make it 2.25????? There is no answer for that, cause its not labeled any where in Yami's manuals. You can try it but, but IMO wouldnt recc. it.
