light flashing on Viper only with H beams
Jeff22
PEI Canada
when my high beams are on my engine light flashes constant on my Viper. Turn the high beams off, the trouble light turns off. There doesn't seem to be any pattern, just a steady flashing and I'm not sure the handwarmers were working or not, never checked. Like I said, low beams, no light though. Any previous experience with this problem??? thanks
Had a similar problem.My tach would would zero and lights were dimmer.
Checked for any rubbed wires under motor,all good.
Done many other diagnosis.
Ended up being a burnt wire right near stator.Resoldered it,been good since.
There's been a few other Vipers around here with same issue.
