gear wear
EricMichael
Presque Isle, ME
Is it alright if the bottom gear has some sharp edges on it on the side of the gear?it seems to be alittle worn down and has peened over the edges alittle. I'm looking to cure a vibration problem. I've taken the chain case apart tongiht, took the secondary clutch off and the jackshaft turn effortlessly with no drag or friction. how do you check your bottom drive-shaft bearings?Anyone have a 70 link chain used/new for sale?how much?
