will cat skis fit yamahas??
Well, yes, but its not direct bolt on, the cat ski uses a american mounting bolt(larger diameter then stock yamaha metric one) and it wont fit thru your spindal bushing unless you drill it out. You also need to space the sides with a couple washers on each side as the saddle is slightly wider.
