Woodydog
01 SRX, when you start the sled none of the lights come on. Turn the sled off and restart no lights come on. Do this 3 or 4 times then the lights finally come on. Could this be another wire deal under the engine or is it something else? Any help would be great.
no, the headlight and load control relay have moisture in them, if you let the sled run they will evenyually come on about minute later, they are not supposed to come on until the engine reaches idle speed, this allows all the power to go to the ign system instead of lights. To fix this take the white(load control) and blue(headlight relay) off the sled and place them on a heat register at minimum overnight, better for a good day and night then reinstall and it should work better.
ReaperSRX
For us electrically challanged were exactly was they be located. I have been having the same problem...........James
Skidooslayer687
above the left footwell under the hood
ReaperSRX
Ah yes, i looked up the parts catalogue and see where they are............thanks...........James
