YAMAHIZAL700
I was just wondering if anyone had a pic of the heel clickers so I could see what came in my srx when I bought it. The weights are hefty and there seems to be just one allen head screw in the tip and it had a solid red primary spring. Not sure on color on secondary but it had a 51-37 secondary. If no one has pics ill post some of mine when I get home. Thanks, Jason
P.s. sled was used when purchased.
bolin22
solid red primary is a HC spring.
YAMAHIZAL700
Im thinking it is, but have you seen the weights? DO they sound like I describe. Real heavy duty and only 1 allen set screw in the tip.bolin22 said:solid red primary is a HC spring.
bolin22
40-10 hclickers should have a large shoulder close to the mounting pin that is threaded (allen screw is one choice). there should be 2 other holes in each weight, one in the middle of the flyweight, and one on the "tip" (farthest from mounting pin/pivot)...these are for adding additional weight where you need it.....thats a total of 3 different spots to add/remove weight......sorry i dont have a pic.
bolin22
ahhh.....i found a pic........http://www.supertorquer.com/Yam.htm
YAMAHIZAL700
That picture is a pic oh Heavy Hitters
YAMAHIZAL700
Sorry, I forgot to mention that. I picked it off their website. I wasnt sure if what I had was heel clickers or not since I had a solid red primary spring.pro116 said:That picture is a pic oh Heavy Hitters
