Belt deflection 82 ET340?
cheesycoolguy
New Brunswick, Canada
I was wondering what the renmended drive belt deflection is for a 1982 ET340. I am not in possesion of an owners or mantience manual. Any info would be greatly apriciated.
I have a '78 et340 service manual and it lists the clutch center distance @ 266mm Yamaha goes by the center distance not by belt deflection. the wear limit for the belt is 26mm :winterrul
The stock setup on the ET is very sloppy .Try and remove as much belt deflection as possible I have also slotted the engine plate to move engine farther ahead. 1" of deflection is good .
