CLutch elingment
fastassyamaha
Lake Orion MI
Website
www.totallyamaha.net
After replacing my heat exchanger i had to move the motor, and after i did that i wondered if my clutch would be out of alignment. it seems to be fine but i want to be sure. whats the easyest way to check the alignment?
15mm offset on a non electric start, 20mm with electric start, and 267.5mm center to center on the clutches. a clutch tool makes this all easy work
