Broken Powervalve cables, need help!!
Sno_Racer_Xtreme
Maine
latly i have been noticing that my 01 srx hasnt been performing like it should so i figured i would check the powervalves, and when i did i realized that two of the cables have broken and need replacing, how exactly do i go about replacing a broken cable, and please put it in fairly simple term because im not really formiliar with them. also does anybody have any idea how much a couple cables are going to cost me?
thanks
forgot that i am not too too formiliar with adjusting my valves when i get them in, i have read some about doing it but i just keep getting more and more confused, when i adjust them do i make the valve right flush with the inside of the cylinder of should i back them off some?
It will be easier for you to just look at how the valve assemblies come apart when replacing the cable instead of having us try and explain it step by step. If you get it apart and can't get it back together, ask us and we'll get you through it.
