marty f
i am new to the forum but i will tell you i have a stock 2000 srx700 and i cannot believe all of the new sleds i still blow away everytime i am out sweet
I still have my 00 SRX around and I agree it has definatly turned some heads, the SRX does things a "little 700" is not supposed to do!!
Oh and welcome to the best Yamaha site on the net!
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Best triple made per CC.
70CHEVELLE
hmmm.....mine does not top end rev 800's? I think I may have a slow one?
70CHEVELLE said:hmmm.....mine does not top end rev 800's? I think I may have a slow one?
What is your rpm's at wot?
70CHEVELLE
About 8100. I know it should be 8400. What is the first thing to check to get the rpm's up a little? Would belt deflection cause this?
-Joe
-Joe
yes i can, but have you cleaned your powervalves? 00-02 srx better hit 8400-8500 rpms.. how are the clutches? stock?
70CHEVELLE
I personally have not cleaned the pv, the clutches I was told is a roller, I know there is a bender helix in it...,maybe a red secondary spring.
shortstop20
- Mar 6, 2005
I remember Mr. Viper saying about a couple weeks ago that the roller secondary's will slow down the SRX on top end. Clean and synch your PV's, get a clutching setup from the guru's here and she'll fly.
i would get on them PV's
If you neglect the powervalve they will gum up and the cables will pull through and the n the valves are junk and it won't pull rpm.This could be your problem.If I lived down there I would help you clean them.There is quite a few members that live near you I'm shure one of them would be glad to help you.
70CHEVELLE
If anyone is in the North Milwaukee area I will pay you to come adjust/clean the valves this weekend?? Pretty please!!
I think n20iroc and yamahaolic22 live near you you may want to try to pm them.
If i lived closer i would help ya too.70CHEVELLE said:If anyone is in the North Milwaukee area I will pay you to come adjust/clean the valves this weekend?? Pretty please!!
chevelle if you do a search on PV's there is allot of reading on them
take your time read and understand how it's done it's very easy to
do plus you should know how sense you own a PV sled..
