marty f
what steps do i need to take to take off the air box on my 2000 srx700
Skidooslayer687
Pull the 2 10mm bolts out of the airbox. Theres one up by the powervalve servo motor and the other you will have to remove the brake air duct to get at. Pull these off then unscrew the boots that go to the carbureators with a phillips screwdriver. Then just pull the airbox out. Its pretty self explanatory
Good Luck
Good Luck
marty f
thanks
i will give it a shotSkidooslayer687 said:Pull the 2 10mm bolts out of the airbox. Theres one up by the powervalve servo motor and the other you will have to remove the brake air duct to get at. Pull these off then unscrew the boots that go to the carbureators with a phillips screwdriver. Then just pull the airbox out. Its pretty self explanatory
Good Luck
